Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
2015 sonic manual 105,000
Old Sep 27, 2020 | 3:56 AM
Jeff Hanson's Avatar
Default 2015 sonic manual 105,000
Treated car good hoping to get 200,000 miles or more. Changed catalytic converter (clogged) 95k and timing belt! To get most out of car. Nothing but issues since P0420 coming on all the time. Anyone having similar issues and problems. Mechanic tried everything that worked with even some freebies. Tried a case # with gm no help due to fact over warranty. Mechanic thinks probably a software issue and thinks should be lemoned out! Any ideas? Thanks!
Old Sep 28, 2020 | 3:35 AM
oilcanhenry's Avatar
Is your Sonic misfiring, using oil, running rich or lean or anything else?
Old Sep 28, 2020 | 3:49 AM
mechanic did state misfiring during bringing back for catalytic converter warranty. No other problems mentioned by mechanic. Frustration set in along time ago wish GM/Chevy take a little more ownership. Understand over warranty but replaced parts and major CEL LIGHT ISSUES!
Old Sep 28, 2020 | 9:29 AM
mechanic did state misfiring during bringing back for catalytic converter warranty. No other problems mentioned by the mechanic. Frustration set in a long time ago wish GM/Chevy take a little more ownership. Understand over warranty but replaced parts and major CEL LIGHT ISSUES!
Things like misfiring or motor oil burning will destroy your catalytic converter. So can the "PVC" system, which is a bad overcomplicated system. Back in the day, you pulled the PVC valve off the valve cover, chucked it in the trash, and installed the PCV valve, total time, 15 seconds.
This Youtube video should help you out, Jeff:
Old Sep 28, 2020 | 8:39 PM
chevyboy@22's Avatar
Default Clogged catalytic converter could be the cause of a faulty oxygen sensor or a loose
[QUOTE=Jeff Hanson;453668]Treated car good hoping to get 200,000 miles or more. Changed catalytic converter (clogged) 95k and timing belt! To get most out of car faulty oxygen sensor or loose gas cap
Old Sep 30, 2020 | 5:02 AM
[QUOTE=chevyboy@22;453741]
If you have too much pressure in the motor, sooner or later seals and gaskets are going to blow. You need to remedy this now.
WyrTwister
Sonic (Aveo)
23
Sep 28, 2020 8:42 PM
nkaufman
Sonic (Aveo)
Aug 16, 2020 8:39 AM
Lisa Fletcher
Sonic (Aveo)
Sep 29, 2017 8:18 PM
WyrTwister
Sonic (Aveo)
May 27, 2015 8:29 PM
