Daytime Running Lights (09 Aveo)
Is there an override switch for the DRL's? DRL should be a personal choice. I understand that it can save lives, but it should still be a personal choice. My Toyota had an override, what gives?
I have been wondering the same thing. I am in the military and we have to dim our lights when going on base and the DRL's are bright even at night. The only type of cut off for the DRLs that i have found is to pull up on the hand break just a bit and they will turn off which is not practical. I was thinking about wiring switch to manually shut them off when needed.
I have a 98 Metro which also has the DRL. In our case there is a switch/relay that if you opened it you could put a piece of cardboard to stop it from making contact. This would shut off the DRL without using the hand brake.
But wouldn't that shut them off all together????
i have the DRL's on my 08. mine when i'm driving i can turn on my park lights and the DRL's go out..mine the DRL's are a lower out put of the head lights, turn on park and it by passes the head lights..
Interesting. Mine they stay on no matter what you do. Running lights, or not etc.
