Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
Thermostat problems (P0597)
Old Oct 28, 2019 | 2:02 AM
  #91
Rui Pinto's Avatar
Default Thermostat heater is necessary?
Hello All, my wife's Chevrolet Spark (2010) has the thermostat heater broken. I have done some tests and find out that the thermostat still open and the engine temperature runs normal (90 C). I think since the thermostat heater warms the thermostat wax for fast opening, without the electric heater the wax heats with the hot coolant and opens in a longer time (but opens). Will I have future problems if I do not substitute the part? Thank you for your attention and regards. Rui from Portugal.
Old Nov 14, 2019 | 9:48 PM
  #92
Dan Gower's Avatar
Default Same problems
Originally Posted by Libby
My check engine light has been intermittently coming on for the past 3 months. Today I stopped by Advanced Auto Parts and they hooked up their scanner to my car and advised that my car was returning a P0597 code.
"Thermostat Heater Control Circuit/Open". I called Chevrolet customer service after reading the many posts from other Cruze/Sonic owners who have experienced the same issue. I was told by Chevrolet's customer service rep "Steph" that in order to determine what is wrong with my car, I need to take it to a Chevrolet dealer and pay them to diagnose the problem. I politely advised Steph that I should not have to pay my local Chevrolet dealer $165. 00 for them to attach their scanner and tell me that the Thermostat /Housing Unit needs to be replaced at XXX amount because my Cruze has 55k miles on it and is past the bumper to bumper warranty. Per Steph, the Thermostat, sensor, or housing unit are not covered under the Power train Warranty and politely advised me to "read my owner's manual to be better informed". I asked Steph why Chevrolet/GM felt the need to use defective/faulty parts and then expect the owners to pay for repairs that could have been avoided? It seens to me that a lot of Chevrolet owners are experiencing this issue, so Chevrolet /GM should see this trend as an issue they need to address at their expense, not their customers. I advised Steph that I have been a loyal Chevrolet Customer, but after this experience, I will make sure my next car will not be a Chevrolet or GM product since customer loyalty in not appreciated by Chevrolet/GM.
This just happened to me again. Fortunately it isn't as cold outside. This will be the fourth time I have had to have it done on my 2015 Sonic in the last 6 months. Each time they replace the housing, thermostat and sensor. Each time I have had to pay $200 in labor to get it fixed. I haven't decided if I'm going to get it fixed this time or just go buy a Ford.
Old May 16, 2020 | 10:59 PM
  #93
Greg J Kallmeyer's Avatar
My 2015 Chevrolet spark engine light is on due to OBD-ll Code p0597, p0598 and p0599 which is heater controlled thermostat is not functioning properly. My Spark only has 16,200 miles on it and is out of bumper to bumper warranty because it's been over 3 years, but this heater controlled thermostat should be covered under the emissions warranty because this type of thermostat is used to improve fuel economy and REDUCE EMISSIONS! Can someone from Chevrolet Customer Service Center contact me to address this issue because it seems to be a big problem on Chevrolet Vehicles that have this type of thermostat?
Old Oct 29, 2023 | 6:25 PM
  #94
AkaSix's Avatar
Default Why
I don’t understand why this hasn’t been recalled or something. My cousin has a 2015 cruise I have 2014 Sonic and pretty much I’ve never seen one not have issues with the thermostat and engine oil cooler . I think this will be the 4th thermostat changed in my sonic…luckily I can do all the labor myself but everyone can’t. Terrible design to put in the cars if they consistently fail
jhinderliter
Nov 15, 2019 9:23 PM
walo_ruiz
Sonic (Aveo)
May 11, 2017 9:22 PM
DVS95Lumina
Dec 24, 2015 3:57 AM
98chevski
Southwest
Nov 26, 2013 5:09 PM
vofsar
Dec 22, 2005 12:32 PM
