Southwest AZ, TX, NM, OK
heater and thermostat problems
Old Nov 25, 2013 | 11:48 PM
98chevski's Avatar
Default heater and thermostat problems
I have a 1998 chevy silverado z71 5.7 that currently has a thermostat and heater problem. I have a week old thermostat rated at 180 and my truck won't hit anything over 140s. I have serviced the fluid level. My truck just won't heat up. I know the gauge works because when I off road it does exceed 200s. Now for the heater im just getting lightly warm air. I replaced the heater hoses. I installed a new heater core and re filled the fluid level. I am still getting cool warmish air. I also noticed no pressure in the system as I can drive for 30 minutes and remove the radiator cap with no pressure or fluid bursting out. The heater core is getting hot I checked the heater hoses and both are equally hot. Please give me your opinions on what the problems might be thanks.
Old Nov 26, 2013 | 5:09 PM
EricBrooks75's Avatar
Thermostat may be stuck open? Best guess I have. There could be something in the heat level adjustment switch too that would be causing it not to allow full heat, but if you can pull the radiator cap, I would guess anti-freeze is constantly circulating.
Jeffro80
Sonic (Aveo)
93
Oct 29, 2023 6:25 PM
jhinderliter
Nov 15, 2019 9:23 PM
corsisica
Sep 6, 2015 4:19 PM
instrumentofwar
Aug 31, 2011 4:28 PM
HHR Ratt
HHR
Oct 22, 2010 9:14 AM
