Spark Originally known as the Beat, , this Daewoo Matiz based 5 door hatchback is newest to the Chevrolet lineup
Chevrolet Spark
2017 Manual Spark Engine Codes Question
Old Mar 17, 2023 | 6:00 PM
ghorton's Avatar
Default 2017 Manual Spark Engine Codes Question
For the last few weeks, my car has made a high-pitched whining noise, especially while idling. I ignored it.
Then today my car showed a check engine light and code 84 (“limp mode”). I couldn’t drive it anywhere until I turned it off and on a few times.
I took it to a mechanic and they said it pulled the following codes:
P0651
P0641
P0697
P06A3
They told me we need to replace the alternator and drive belt, and it would be $890 (in Nashville).
1. Is there any way these codes relate to an alternator? The internet said it’s just a computer thing that needs to reset.
2. If it is indeed an alternator, am I getting ripped off?
Old Mar 17, 2023 | 7:56 PM
the codes ...all of them set when the ecm detects a short to grd or voltage on the 5 volt reference circuit.
typically this problem would be wiring or a bad ecm.
if the noise is coming from the alternator...you need an alternator. If the belt is worn or glazed you need a belt. If you asked the shop to find the source of the noise...that is what they did. the dtc seem unrelated.
they will charge you diagnosis time maybe 1 hour + parts+ part replacement time 1 hour labour.
Chopperdoc
Mar 27, 2024 3:10 PM
crabbydad
Dec 27, 2015 9:50 PM
MFY
Nov 10, 2015 2:03 PM
wolfdogg
Feb 20, 2012 11:29 AM
northamfishing
Sep 23, 2007 5:58 PM
