Spark Originally known as the Beat, , this Daewoo Matiz based 5 door hatchback is newest to the Chevrolet lineup
Chevrolet Spark
Half black half white spark plugs on each cylinder
Old Apr 12, 2023 | 7:46 PM
kjetil4455's Avatar
Unhappy Half black half white spark plugs on each cylinder
Hi guys,
This is my first post here. Thanks in advance for sharing your knowledge and expertise. I really appreciate it.
I don't have so much expertise in car mechanics but I do a bit of work on motorcycles (hobby).
Either way, I have just bought a 2007 spark for my girlfriend. It seemed an OK buy at first, engine sounds fine, fairly low milage (60 000; presuming it's not tampered with), healthy looking exhaust etc.
I started doing some maintenance and started seeing one thing after another. First, there was water rather than coolant in the radiator reservoir. The owner is a mechanic, so this worries me. We just drained that today and added coolant, but I fear that we're going to experience wasting of the liquids due to whatever underlying cause.
Next we changed the oil, AC and fuel filters. Took the spark plugs out to get an impression of the combustion efficiency. Unfortuantely I was presented with very strange "half half"-looking spark plugs, where one side (of the very same ignition site) was white (very lean) and one side black (oil? Carbon?). Sadly I didn't take a picture. All of the spark plugs looked the same; half and half. The mechanic suggested it could be burned exhaust valves, but seeing as they all look the same, I don't think it is so likely. I read online that it could be a timing problem. This worries me, especially as it sounds more likely. The car isn't misfiring but it seems to lack a lot of performance (granted, it is just a 4x1000cc engine after all, but it feels dull, and I also feel that it is consuming more gas than it should). I also read it could be a gas pump problem, but I don't see how that would cause the half and half appearance that I am presented with here.
At this point I am starting to fear that I might have bought a rotting car. There was some oil in the breather hose (didn't look terrible) and a very slight oil leak from the front part of the gasket in the oil pan (sorry if this isn't the correct term). No oil in the coolant (well, water....), no black or ugly exhaust. Engine sounds fine to me, but I am not an expert.
I would be very very grateful if anyone has seen this strange spark plug appearance before and tell me what it could be.
Old Apr 13, 2023 | 10:48 PM
oilcanhenry's Avatar
Originally Posted by kjetil4455
Hi guys,
Never have seen this condition on any spark plug and I am not young. If they are older, I'd replace them with iridium spark plugs. Only thing I can think of is water/coolant hitting the side of the plugs, which possibly means a head-gasket leak.
Old Apr 14, 2023 | 6:04 PM
kjetil4455's Avatar
Thanks a lot for your reply.
I checked today that there's absolutely no evidence of coolant in the oil nor is there white exhaust or exhaust bubbles in the coolant. I think the head gasket is OK.
We took out all the spark plugs again and today it wasn't as 50/50 as last time; strangely. Some had a lot of carbon deposits and some were showing evidence of poor air fuel ratio.
Took the injectors out and two out of four injectors were failing pretty miserably, which is probably the main issue. I replaced all four; the car is 16 years old after all. We also had a look at the timingbelt, and the sync was 1 tooth off (and was loose; tensioner was failing), so we changed the belt, the water pump and also the oil retainers on the cam and crank axels ---> and, of course, fixed the sync.
Regarding the coolant wasting, thankfully it turned out to be some rotten hoses. We changed those as well. The car was using a ton of fuel and had poor performance. It seems to be OK now. I think the injectores were the main issue as they were really dysfunctional.
silverado2001
10
Dec 16, 2020 3:45 AM
wbywmu
1988 - 1998 (GMT400)
Oct 26, 2017 6:26 PM
Brendan Baker
Jul 29, 2012 11:46 PM
peedeefish
Sonic (Aveo)
Jan 16, 2010 10:31 PM
Mike Sigmond
Apr 30, 2009 10:55 AM
