Suspension & Tire Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Got sleek low-pros or gnarly mudders? Step in and let's talk about 'em!
85 Chevy loose steering
Old March 18th, 2012, 7:37 PM
1985 454's Avatar
Default 85 Chevy loose steering
I bought a 85 Chevy k10. It has 3 inch lift blocks in the front (already on when I bought) and I'm not sure how big the leaf springs are but the truck has 39.5 super swampers. When I try to drive it the steering isn't tight or anything but it's all over the road the steering is really loose and I'm not sure why any help???
Old March 20th, 2012, 10:18 PM
cleveland63b's Avatar
probably needs a whole new front end/steering rebuild. Its old with im assuming lots of miles and lift kits make everything wear out quicker.
Old April 7th, 2012, 7:30 PM
Gundog's Avatar
Cleveland is correct, but I would try this. On the top of the steering gear box there is a nut with a protruding threaded bolt. Some have a slot for a screwdriver others hold an allen wrench. Try loosening the nut while holding the bolt in place. When the bolt is loose, turn the bolt 1/4 turn. If that helps a little, turn another 1/4 turn. Do not over do it as this closes the gape in the gears and you want a little play in them. Just my .02
JT Kessler
November 26th, 2020 8:14 PM
biglg
November 1st, 2010 10:15 AM
lots of lunch
February 19th, 2007 6:32 PM
rmattson
February 9th, 2007 1:08 AM
dwilson6881
Silverado & Fullsize Pick-ups
June 2nd, 2006 4:23 PM
Quick Reply: 85 Chevy loose steering
