04 burb liftgate won't open
Old Jan 3, 2015 | 7:56 PM
stayathomedad's Avatar
Default 04 burb liftgate won't open
My 04 liftgate is stuck closed. The gate or the glass won't move. It sounds like it is unlocking but nothing will move. Is there a way to open it from the inside? Is there a common problem like this? The gate is manual, no power
Old Jan 3, 2015 | 8:05 PM
this is for the 2007 and up, but you might give it a read and see if it might apply
https://chevroletforum.com/forum/tah...l-power-69087/
Old Jan 4, 2015 | 11:24 AM
Update
After locking and unlocking several times it opened. I pulled the rear panel and everything looks fine, nothing bent, broken, or not connected. So I don't know if it was operator error, something sticking or something else.
I'm just thinking about unplugging the lock actuator so I can still open it and leave it unlocked for the winter and mess with it in the summer when it's not 10 degrees outside.
If it won't open, I found that if you crawl inside the talegate panel is 2 pieces and you can bend the bottom piece open enough to unlock it manually, it;s right there and takes 2 seconds.
Old Jan 4, 2015 | 1:55 PM
Thanks for the follow up, keep us updated if you find out what the cause was should it come back...
remtlm
Jan 16, 2020 8:41 PM
daman77
Nov 14, 2013 6:53 PM
The_Stees
Mar 5, 2013 8:20 AM
swa737flyboy
Sep 7, 2011 1:48 PM
kdogg121
Astro
Sep 6, 2008 3:22 PM
