04 escalade rear heat not working
Old Dec 12, 2008 | 12:20 AM
fordsho90's Avatar
Default 04 escalade rear heat not working
I'm new to this forum, Would anyone know why my rear heat only blows cold air?? I read it might be an actuator.. but I would not know how to get to it to check. Anyone have pictures they could possibly share? Even if I can manually change it to heat for the winter then come warmer temps I could change it back? Please help....
Old Dec 12, 2008 | 9:56 AM
Default RE: 04 escalade rear heat not working
2000–06 Vehicles[*]Remove the right rear quarter trim panel.[*]Disconnect the electrical connector from the actuator.[*]Remove the retaining screws from the actuator.[*]Remove the mode actuator from the housing.
Actuator location, typical[/align]
[ol][/ol]
To install:[*]Install the mode actuator to the housing.[*]Install the retaining screws to the actuator and tighten to 14inch lbs. (1.6Nm).[*]Connect the electrical connector to the actuator.[*]Install the right rear quarter trim panel.
Calibrate the HVAC module actuators, if required.
[ol]Air Mix/Mode Actuator (Blend Door)
Escalade, Suburban, Tahoe, Yukon, Denali, Denali XL, Yukon XL, 1999 – 2005[/ol]
Old Dec 12, 2008 | 11:25 AM
Welcome to the Tahoe forum. Hope that helps.
thehig
Uplander
Nov 26, 2009 9:11 PM
1981camaroz28
Oct 28, 2007 6:45 PM
tumark
Apr 15, 2007 12:58 PM
