04 suburban electrical issue
I have a 04 suburban that recently starting acting funny in November I change the alternator all was fine till last month when lights started flickering battery is good I checked it with my volt meter. Went to autozone had alternator checked its good as well. I can watch the battery gague fluctuate from 14 volts to 15 volts but when I have my volt meter on the battery it stays a consatant 14.4 volts connections on the battery are tight and not corroded kinda at my wits end any help would be appreciated thanks
Don't just check your battery connections at the battery, but at the other end also. It is real important that the negative cable has a good tight corrosion free connection at the other end. Looks like you have a bad ground somewhere.
