04 suburban electrical issue
Old Mar 11, 2013 | 5:58 PM
Cmudder1979's Avatar
Default 04 suburban electrical issue
I have a 04 suburban that recently starting acting funny in November I change the alternator all was fine till last month when lights started flickering battery is good I checked it with my volt meter. Went to autozone had alternator checked its good as well. I can watch the battery gague fluctuate from 14 volts to 15 volts but when I have my volt meter on the battery it stays a consatant 14.4 volts connections on the battery are tight and not corroded kinda at my wits end any help would be appreciated thanks
Old Mar 11, 2013 | 6:22 PM
kevinkpk's Avatar
I'd recommend since you say lights fliker, make sure the connections are tight. If you are using a digital VOM without an analog bar, you might not see a lag in the voltage due to a slightly loose connection.
Old Mar 11, 2013 | 7:16 PM
Don't just check your battery connections at the battery, but at the other end also. It is real important that the negative cable has a good tight corrosion free connection at the other end. Looks like you have a bad ground somewhere.
yaryar1
May 12, 2015 7:53 AM
idaphin
Nov 7, 2013 12:40 PM
shandy225
Mar 25, 2010 12:14 PM
