04 suburban front wheels locked
Old Dec 19, 2012 | 2:39 PM
gordie1465's Avatar
Default 04 suburban front wheels locked
My 04 suburban front wheels locked and abs ,stability control light on and engined slowed down in limp mode ,Is this a sign of bad wheel sensors or what?
Old Dec 19, 2012 | 2:56 PM
Welcome to the forum
It could be, have any codes be set?
You could try re-seating the wheel sensor connections, might also want to check your battery connections for corrosion and tight fit esp the ground cable...
Disconnecting the battery will clear any codes you have so check them first...
bfjones
Aug 16, 2019 7:37 PM
EvilestRug
Aug 4, 2013 10:46 AM
w4audi
Aug 2, 2013 10:01 PM
PKKK
Mar 1, 2012 11:52 PM
oldtimer50
Jul 14, 2006 10:14 PM
