'05 burb 110K miles- when to chg shocks
Old Jul 5, 2012 | 9:14 AM
Jimsu's Avatar
Default '05 burb 110K miles- when to chg shocks
My '05 burb has 110K miles aand we use to pull a trave travel. My NTB service center says it cost $900 to replace shocks because of some crazy shock absorber technology these use in these Suburban.
These are the original shocks should they be changed? Is there a cheaper way to handle the service?
Old Jul 5, 2012 | 10:49 AM
As long as they are working correctly, don't change them.
Old Jul 5, 2012 | 12:13 PM
They are probably old and worn enough to change... I'd pull the rear ones off at one point, and see how they respond if they still have some resistance and return pressure in them they are probably good for a bit longer... if they stay put or are really slow to return from compression they are probably ready for replacement... If they show obvious leaks then you for sure have your answer...
Old Jul 6, 2012 | 10:06 AM
See post #9 here.
This is a more economical way to replace the Autoride system w/ conventional shocks.
Wakko
Apr 7, 2014 10:15 AM
ag2
Jan 9, 2013 9:10 PM
sclserviceCHAMBERS
May 16, 2011 10:32 AM
Surfurban
Mar 2, 2009 7:29 AM
willcunningham
Feb 23, 2009 4:45 PM
