05 Suburban random misfire
#21
Further testing swapped five with seven. Now p300 code only. Also hate to say this but less of a burnt fuel smell and a more foul smell. Check engine light flashes for a couple of minutes shuts off and repeats. Runs a little rougher after swapping.
#24
Need to check the wiring to the coil packs, also check the cam and crankshaft position sensor wiring, make sure nothing is burnt, pinched or broken
#25
Looks like new fuel cleared random misfire. Reset codes this morning and drove for forty five miles with no Codes. Only error now is p305 at an extended idle only. Reset on return trip and no codes until a idle
#26
Pulled #5 plug. Looked fine. Noticed the coil was a little loose. Tightened it up. Took another 30 mile test run. Only time I got an error code was when I let it idle for a minute. Check engine would flash about thirty times and clear itself. No codes under a load. Shows a p300 pd code but never recorded it
#27
Cheap gasoline is cheap for a reason. ARCO saves money not using credit cards, but that's only 3 percent. The rest of it is spent lying on their ad's, and using cheap gasoline at all times. It's OK to use cheap gas once in a while, but all the time spells trouble just waiting to happen.
I've seen how spotless a carburetor was using Techron Chevron gasoline, Having a 22-year-old Chevy pickup with the old style fuel poppet injectors, I've not had any issues at all.
Nox2007
June 16th, 2017 2:45 PM
dogman1313
September 22nd, 2014 10:22 AM
