07 LTZ air leaking from back glass
Old Oct 7, 2006 | 3:05 PM
Brady's Avatar
Default 07 LTZ air leaking from back glass
With the AC running I can feel and hear air leaking from the lower edge of the back hatch glass. Does anyone else have the same problem?
Old Oct 7, 2006 | 3:22 PM
bjaber's Avatar
Default RE: 07 LTZ air leaking from back glass
Wouldn't that be normal venting? ???
Old Oct 7, 2006 | 5:13 PM
tahoe07's Avatar
I haven't had any leak issues with the rear glass.
It's not normal for the air to flow at rear glass. There are rear vents to release pressure and fresh air comes from front.
Old Oct 7, 2006 | 10:01 PM
phoenixcorvette's Avatar
That is adnormal...must be that the window seal is misaligned,,
Old Oct 9, 2006 | 12:17 PM
ZX1100F1's Avatar
The exhaust vents for the flow-thru ventilation system can only accommodate so much air flow, if you have both the front and rear blowers on high the system exceeds the total cfm volume of the vents, the excess pressure in the cabin will be relieved via the rear glass just as you describe, it is normal.
We initially had the rear glass hatch set tight so it would not vent but then the air would rush thru the door panels and handles and cause a whistling noise.
Old Oct 11, 2006 | 2:56 AM
Brady's Avatar
While towing a cargo trailer I am also getting a loud whistling sound from the rear of the Tahoe. I am guessing that it's coming from the rear hatch glass. I owned a 2000 "new" Tahoe LT(112,000 miles) before and never had any of these problems.
Old Oct 11, 2006 | 11:42 AM
ZX1100F1's Avatar
Have your rear cargo door and lift glass latches adjusted, it sounds as though yours aren't quite snug enough.
Also keep in mind that at highway speeds there is a tremendous low pressure zone created between the rear of the Tahoe and the front of the cargo trailer, every vehicle will react differently to this. but it still sounds as though you just need a simple adjustment.
Old Nov 5, 2006 | 11:21 PM
07tahoelt's Avatar
ORIGINAL: ZX1100F1
I am getting the same problem as described above when towing a cargo trailer. The noise is annoying and I am concerned it could allow exhaust gases into the cabin. Has anyone had their dealership make the adjustment ZX1100F1 suggests? Does it remedy the problem?
rifsm1
Jul 15, 2015 5:11 AM
William Mark Brown
Aug 26, 2013 11:13 AM
dtachia
Apr 23, 2011 1:51 AM
jntrox
Oct 19, 2010 6:03 AM
b1pig
Dec 10, 2006 9:13 PM
