07 suburban driver info ctr
Old Jul 22, 2010 | 4:25 PM
07suburbanLTZ's Avatar
Default 07 suburban driver info ctr
Driver information center display has quit. There might be a hint of glow (barely visible) in the PRD321 area. Had local shop (not dealer) look at it and said LCD display needed replacing-- would be more than $800 by the time chevy programmed it. He said that he was able to make it come on but only to cut out again- you can actually slap the dash above and occasionally it will display but only for a short time.
Am I screwed?
Old Jul 22, 2010 | 9:21 PM
MDTAHOE's Avatar
Professional Mechanic
http://www.mrwhizard.com/index.cfm
Check this link out. They maybe able to help you. I have sent out a few Lexus clusters and A BMW cluster before, it saves alot of money. I have never used this company though, there are probably many others out there.
Old Jul 22, 2010 | 9:39 PM
Welcome to the forum.
If the display is mounted on a PWB and slapping the dash causes it to work, then could be a cracked solder joint or broken circuit path. A lot of the expense is probably the labor in removing it.
Old Jul 22, 2010 | 10:09 PM
I second that notion... if you can slap it and make it work, its probably a poor connection..might be worth just pulling and re-seating the IP cluster connections...
00palanightmare
Sep 26, 2015 7:08 AM
jair143
Sonic (Aveo)
Mar 3, 2011 5:31 AM
adamant
Feb 17, 2009 2:54 PM
ssb1bickel
Nov 15, 2007 5:51 PM
bper1234
Cobalt
Jul 11, 2007 1:21 PM
