07 Tahoe Auto Dimming on NAV
Has anyone noticed that when the Nav unit is on Auto Dim that is always displaying in bright? I really like it when it's dimmed at night as it really softens the feel in the cabin. Any thoughts comments or solutions would be appreciated.
RE: 07 Tahoe Auto Dimming on NAV
You can switch it from day to night or with the navigation disc in you can press and hold the steering wheel mute button for a second until you get a beep. Then say "Display, Night Mode" and it will darken. You can also do day mode.
Does this only work with a nav disc installed? And does it then also influence the audio screen light?
I don't have a nav disc, since nav doesn't work in Europe, but I am extremely annoyed about the bright blue screen at night. So far I have only found out to turn it off (and mute the system as a kinda "off").
yes, it only works with the nav disc installed. When you change to night mode it makes the nav screen go from bright yello/white background to black/yellow background. It also dims the intensity of the light from the nav unit. You can set how dim or light in the brightness and contrast settings.
