07 TAHOE BRAKES SQUEAKING!
Old Apr 10, 2008 | 9:25 AM
  #21
74chevy4life's Avatar
Default RE: 07 TAHOE BRAKES SQUEAKING!
This problem is genneraly a common problem cause by moisture, rust, and dirt on the rotors, (but not in this case) but just to warn everyone if you do go to the local autoparts store the cheap break pads you can by there will also case that annoying squeak just a heads up
Old Oct 5, 2011 | 7:41 PM
  #22
Linda Davis's Avatar
My 2007 Tahoe is screeching to high heaven and very embarrassing! It sounds like metal on metal. It starts off loud and gets worse when coming to the last seconds of braking. I've had three sets of brakes in three weeks, the rotors turned twice, a new drum on back brake and a new caliper. I'm desperate and now broke. Please help if someone figures this out. I agree that a $50000 truck should not be doing this.
Old Oct 5, 2011 | 7:54 PM
  #23
Originally Posted by helimike77
I had the same issue with my 07 Tahoe. The dealer said they arent normally covered after 10,000 miles but since they saw a tsb he replaced them. According to the service writer the new ones are a different pads from the one it came with. Been 2 weeks and no squeaks .
Please find out exactly what kind of pads they are so you can help a lot of people stop their Tahoe brake misery.
Old Oct 5, 2011 | 10:59 PM
  #24
Linda Davis Welcome to the forum...
sorry to hear about the brake troubles, a set of quality ceramic pads should eliminate the squeal...also it is best to have the rotors replaced rather then turned, when they are turned material is removed and reduces the amount of cooling capacity of the rotors leading to warping....
Old Oct 6, 2011 | 8:23 AM
  #25
Mad Dawg's Avatar
Totally agree.
I just replaced the front pads and rotors on my 07. They had 75k on them. I used factory rotors and Hawk HPC pads. I highly recommend these pads. No issues whatsoever with squeaking/squealing. I also used caliper grease to lube up everything up.
Linda, did the shop or whomever worked on your brakes use caliper grease?? That could be why you are having such problems. Grease should be used on the caliper pins as well as on the back of the pads where the pads and calipers make contact.
Old Oct 9, 2011 | 8:24 PM
  #26
So are you saying that the shop that did the work isn't standing behind it?
Old Nov 26, 2011 | 1:18 AM
  #27
Alfil's Avatar
Default 07 tahoe brakes squeaking!
My truck does the same noise when rains or is really humid. The noise is really loud and it bothers me alot, 'cus in my case if its a rainy or humid day the noice doesn't go away not matter how many miles I drive!!
quote=engine2;24048]I believe the noise to be from condensation forming on your brake rotors then slightly rusting. I believe that is why the noise goes away after the brakes get warm. It only happens to me when humidity is real high or alot of rain fell the night before. I am not worried about it.[/quote]
Old Nov 26, 2011 | 7:24 AM
  #28
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Alfil,
I am sorry to hear about your frustrations with the brakes on your truck. Have you had the chance to stop by your local dealer and have them check them out? If you would like to PM me your VIN number, name & mileage, I can look into this further for you. I look forward to your response.
Louis
GM Customer Service
regit65
Sep 10, 2017 3:59 PM
squeakytahoe
May 11, 2017 4:36 PM
dstanely
Jul 3, 2014 8:19 PM
benndez9
May 25, 2007 7:58 AM
