07 Tahoe crank, no start
Hey guys. My 07 Tahoe 5.3 won't start but it'll crank, I have spark, 55psi fuel pressure at the fuel rail, replaced the crank position sensor, cleaned the crank sensor ground and cam sensor ground under the truck in front of the driversside motor mount, and cleaned the negative battery terminal and ground on front passenger side of the block. It was running great drove it to the store parked it got in it six hours latter, started it was running fine forgot something inside shut it off, came back out started it again, and it was running really rough, shifted into drive drove 20' stabilitrak/traction control notifications engine light came on, parked it and shut it off, now it will crank sounds a little slow, but won't start. my fluids are fine I've never dogged it, the engine light is on but its not throwing me a code on any of obd2s I've used, on crank its not registering RPMs on crank. Its got 120k miles, oil smells a little like oil. Any help would be greatly appreciated.
chevykid1994
January 20th, 2015 10:44 PM
