07 Tahoe crank, no start
Old Oct 3, 2024 | 5:25 PM
Durtycurty840's Avatar
Default 07 Tahoe crank, no start
Hey guys. My 07 Tahoe 5.3 won't start but it'll crank, I have spark, 55psi fuel pressure at the fuel rail, replaced the crank position sensor, cleaned the crank sensor ground and cam sensor ground under the truck in front of the driversside motor mount, and cleaned the negative battery terminal and ground on front passenger side of the block. It was running great drove it to the store parked it got in it six hours latter, started it was running fine forgot something inside shut it off, came back out started it again, and it was running really rough, shifted into drive drove 20' stabilitrak/traction control notifications engine light came on, parked it and shut it off, now it will crank sounds a little slow, but won't start. my fluids are fine I've never dogged it, the engine light is on but its not throwing me a code on any of obd2s I've used, on crank its not registering RPMs on crank. Its got 120k miles, oil smells a little like oil. Any help would be greatly appreciated.
Old Nov 18, 2024 | 1:51 PM
Dannyphaup's Avatar
Will it run if u spray starting fluid
Dannyphaup's Avatar
WI'll it run on starting fluid
Old Nov 20, 2024 | 7:57 AM
Cusser's Avatar
Apparently I've developed cataracts for this thread only.....
Old Nov 20, 2024 | 2:15 PM
jfmorris's Avatar
Yeah.... light grey text on a light grey background is kinda really hard to read. How/why would someone type a question like that!
mmartin8888
Nov 9, 2022 10:01 PM
2001sunfire
Oct 26, 2021 3:51 PM
chevykid1994
Jan 20, 2015 10:44 PM
freshnclean
Mar 23, 2014 8:50 PM
travismm
Feb 25, 2014 4:09 AM
