07 Tahoe cruise control
Old Jul 29, 2008 | 10:36 AM
jj's Avatar
jj
Default 07 Tahoe cruise control
My problem: Cruise control will not hold set speed when going down a long hill. ( If I set it at 70 by the bottom of hill I'm going 80) I just returned from dealer who said they contacted GM Tech Services and were told the engine "LOCK OUT" ? is not installed on 07 Tahoe engines so therefore no speed control going downhill! Is this true or are they trying to blow me off? ...
Thanks for any insights on this problem you might have. J.J.
Old Jul 29, 2008 | 1:36 PM
Default RE: 07 Tahoe cruise control
True.
Old Jul 29, 2008 | 5:01 PM
shawnvw's Avatar
Banned
The cruise control cannot apply the brakes or downshift for you. It merely applies no throttle when going faster than it was set to
Old Jul 29, 2008 | 5:21 PM
Does tow/haul downshift any?
Old Jul 29, 2008 | 6:15 PM
jj's Avatar
jj
I Haven't towed anything on a long down hill grade. But the tow mode does work. You can see the RPM go up when you hit the button.
Old Jul 29, 2008 | 8:26 PM
Was that when you were going downhill when you turned it on? If so, how fast?
Old Jul 29, 2008 | 8:38 PM
jj's Avatar
jj
Cruse was set at 70mph on level road. it was a long down grade and the Tahoe picked up speed the further down we got. At 80mph I started using the brakes to slow down.
Old Jul 29, 2008 | 10:02 PM
jj's Avatar
jj
I think I may have figured out why the Tahoe picks up speed on the downhill side. Old Tahoe uses all eight cylinders to helpslow the vehicle when no pressure on gas pedal. New 07 Tahoe only uses four cylinders when there is no load on the engine reducing engine drag (Good for gas mileage) but not helping slow the car on downgrade. The longer the downgrade the more time the Tahoe has to pick up speed. Thanks to all for helping clarify problem.
Old Jul 29, 2008 | 10:17 PM
The engin still has to move all 8 jugs (pistons) no matter what mode its in and the values are still going thru there motion. I suspect it could be a combination of transmission, gearing, wind directionand the load you had that increased speed. I just returned from a long trip using the cruse and many down hill grades and lost speed going downhill when I disengaged the cruse due to wind resistence.
Old Jul 29, 2008 | 10:42 PM
jj's Avatar
jj
The difference is compression in only four cylinders instead of eight.
pcwilcox
Oct 21, 2013 11:00 AM
liljoe66
Aug 5, 2011 12:44 PM
tkdunn
Jun 20, 2010 11:15 PM
kbridge234
Sep 4, 2008 10:03 AM
98tahoe48
May 29, 2007 6:17 PM
