07 Tahoe LTZ bose amp problem
Old Mar 29, 2013 | 1:09 PM
canfxit1's Avatar
Default 07 Tahoe LTZ bose amp problem
I purchased this 2007 Tahoe LTZ I have been hearing feedback and whining coming from the rear speakers which the whining gets louder on acceleration. Then it will disappear and come back ever so often while driving. I'm also asking if a alternator could cause this because I have noticed the gauge will either fluctuate between under 14v and over 14v. If the amp is bad is it located between the two front seats under the console and if so where can I get a replacement one then.
Old Mar 29, 2013 | 9:02 PM
mulmur1's Avatar
Welcome to the forum.
Do you get any static or poor quality sound from the sound system when the engine is not running?
It is also possible that there is a short in the speaker wire to one of both rear speakers. You may want to check each speaker, but disconnecting it and seeing if the problem improves. If it does, you may have a wiring short in the door. This is common as the wires wear over time.
You are right that the amp is located under the center console. It is a job to remove it. It is possible that the amp needs to have a better ground. It is also possible that the amp is no longer working properly.
There are lots of better alternatives to the Bose amp. You may want to contact Crutchfield.com and discuss a sound system upgrade.
For comparison the original amp is available through gmpartdirect.com for $327.78 list , $170.45 online. An aftermarket amp would provide more options and a better sound, but it depends what you are looking for.
Good luck with your repair.
Old Aug 27, 2013 | 6:30 AM
joeincharlotte's Avatar
Not sure if you got this fixed, but I had the same problem. It was the rear radio controls. Replaced it and it went away.
Old Aug 28, 2013 | 8:19 AM
canfxit1's Avatar
Question 07 Tahoe LTZ bose amp problem
I haven't fixed the problem since then because the weather turned warm and the problem has since gone away. It only seemed to perform this when the weather is cold if that means anything. Will have to wait for the temps to dip below 50 to see if it repeats itself.
Old Aug 28, 2013 | 9:58 AM
Sounds like it could a be a loose connection that gets worse or only happens when things contract due to the cold...
might try pulling the rear control panel and re-seating the connections....
Old Jan 4, 2015 | 4:51 PM
Rumrcity's Avatar
Default Repair made?
I was hoping a fix might have been posted regarding this. I have a 2007 LTZ with a similar problem, only difference in problem is I'm getting the noise in "all" the speakers on the right side. The noise is not present when vehicle is cold but will happen after warm up and then typically after driving on over a bump. The speakers still produce audio but the whine/noise is there and the pitch/tone changes with accelerator usage. I've disconnected rear audio control and still had noise in all speakers, reset plugs on the speakers and still had noise. The other odd thing is when the noise is there and I shut down engine, the noise remains until opening the door. I'm leaning toward replacing the amp, but before taking on this somewhat monumental task, I figured I'd inquire about a fix. Any assistance would be appreciated, thanks.
Old Jan 5, 2015 | 5:21 PM
canfxit1's Avatar
Default Re: Radio noise in Tahoe LTZ
After further testing of the vehicle this summer we determine the problem does lie in the rear radio control unit. Suggestions were to remove the unit and check the connections on the back of the unit. If by disconnecting and reconnecting the unit did not fix the problem replacement of said head unit needed to be replaced.
Old Jan 6, 2015 | 1:19 PM
Rumrcity's Avatar
Thank you for the info.
Ryno
Aug 16, 2012 6:26 AM
silberm3
Jul 16, 2010 8:13 AM
vette40509
Mar 5, 2010 10:29 AM
latif99
Jul 4, 2009 6:22 PM
fakhir1234
Feb 27, 2009 7:41 PM
