07 tahoe nav install questions
Old Mar 16, 2007 | 1:40 PM
johnson374's Avatar
Default 07 tahoe nav install questions
I just installed nav in my tahoe and two questions:
1. The VSS isn't working and I used the JP Customs kit to the green/white wire. Anyone had this happen to them, or know how to fix it?
2. The clock can't be set, is it because the gps antenna isn't installed yet? I already had the unit flashed so the radio is working.
Thnaks, Chris
Old Mar 16, 2007 | 1:48 PM
jlenkows's Avatar
Default RE: 07 tahoe nav install questions
you're on the wrong Green/wt. wire. I'll bet that your thermometer on the mirror is wrong too!!!
Old Mar 16, 2007 | 2:18 PM
johnson374's Avatar
Great, I'll look again I thought their was only one green/white wire back there.
Know why the clock doesn't work?
Thanks.
Old Mar 16, 2007 | 2:28 PM
xclusive's Avatar
the green and white wire is in the bcm and i believe there is 2 of them so u will have to test them both. also if u do a search there is some info about a gps install and it has a pic of where exactly u need to go to find the vss wire. if u still cant find it u can always go to the wheel.
Old Mar 16, 2007 | 6:34 PM
jlenkows's Avatar
Check this out:
https://chevroletforum.com/m_5604/mpage_16/key_/tm.htm
Old Mar 16, 2007 | 6:55 PM
biglg's Avatar
Your clock wont set? Have you driven it down the open road? Out of the garage? Mine just took a while for it to set the other day when I removed the HU.
Old Mar 17, 2007 | 1:02 AM
johnson374's Avatar
Yeah I have driven it down the road, but I don't have the gps antenna yet. Maybe that has something weird to do with it??
I did find the corrct grn/wht wire on that right though, thanks guys!
Old Mar 17, 2007 | 1:18 AM
johnson374's Avatar
VSS still doesn't work anyone know if the gps antenna would affect that maybe?
Old Mar 17, 2007 | 1:52 AM
gm_geek's Avatar
ORIGINAL: johnson374
your Nav Radio clock will not work without GPS antenna connected, as well as few other functions.
if antenna is not connected , your Nav does not know your vehicle position
Old Mar 17, 2007 | 1:59 AM
johnson374's Avatar
Thanks for answeringthat question. Hopefully hooking up the GPS antenna will fix theVSS not woking either!!!
