07 Tahoe Rear Lift Gate Window won't Open
Old Jul 4, 2011 | 9:23 AM
4collins's Avatar
Default 07 Tahoe Rear Lift Gate Window won't Open
Any help with this would be appreciated. I have an 07 Tahoe without auto liftgate. I pushed the botton to open the rear window and now it will not work. There is no noise or anything. I looked in the manual assuming that it must be a fuse but I did not find anything. I still think that that may be the problem but any assistance would be greatly welcomed.
Old Jul 4, 2011 | 7:54 PM
Welcome to the forum.
You'll need to remove the inside panel and check for voltage at the switch and verify that the switch is working. If it is, then check for voltage at the lock actuator. Also check grounds.
Old Jul 5, 2011 | 8:05 AM
ousig2408's Avatar
I assume you have tried it with the remote and the button above the plate?
Old Jul 6, 2011 | 2:39 PM
Official GM Rep
4collins,
I have the same question as ousig2408. Did you try opening it any other way?
Thank you,
Elizabeth, Chevrolet Customer Service
Old Jul 10, 2018 | 4:15 AM
Onelegger's Avatar
Default 2010 tahoe help please
I'm stumped, u have a 2010 tahoe ls 4wd ppv. The rear liftgate works fine but the wiper doesnt work and the liftgate glass wont open. Neither the button on the liftgate or the one on the fob do anything. I popped the panel off kinda cut u cant take it off without opening the glass everything looked fine. Please help.
Old Mar 26, 2019 | 9:10 PM
Lauckt's Avatar
Default Did you figure out the issue? I have a suburban with the exact same problem
did you figure out the issue I have the exact same problem with my suburban?
Old Mar 16, 2023 | 12:58 AM
ben2far's Avatar
Have the same question 2007Suburban LTZ - replaced button but neither button or remote will open the window so how can you get the back cover off to check or replace the mechanism that opens the window?
Old Mar 16, 2023 | 7:36 PM
Old Car Guy's Avatar
Default Lift gate inop
I have found that if the wiper motor is not working properly, it won’t let the lift gate operate. Try a new wiper motor
black99gm
Feb 22, 2021 4:00 PM
dolljason.p
Jul 25, 2020 8:36 PM
JAJohnson911
Aug 2, 2015 1:43 PM
TomS209
Jul 23, 2015 12:22 PM
Davpmars
Jun 6, 2014 8:39 AM
