07 vibration while in v4 mode
Old Nov 2, 2008 | 8:44 PM
  #11
Default RE: 07 vibration while in v4 mode
I have been running a bottle of fuel injector cleaner thru at about every 8k miles and also use Chevron gas.(top Tier) and also use Shell from time to time (also top tier)
I have been using the 3M brand fuel injector cleaner but will switch to the Techron
Not that it matters but here are some links,
Amazon reviews
http://www.amazon.com/review/product...owViewpoints=1
Wikipedia
http://en.wikipedia.org/wiki/Techron
EDIT and one more from another forum
http://www.nissanforums.com/truck-su...ntrations.html
Old Nov 5, 2008 | 4:58 PM
  #12
SabrToothSqrl's Avatar
not specific to your issue; but just a general question... the DIC tells you if its 4 cyl or in 8 mode right?
say your cruising along... 50 MPH in V4.... then you turn on the A/C....
can it run just in 4, or does the A/C need all 8?
just wondering!
Old Nov 12, 2008 | 7:16 PM
  #13
Under some conditions, the A/C w/ drop it out of V4 mode. All depends on the load on the engine.
Old Mar 5, 2021 | 2:14 PM
  #14
Ray Cisero's Avatar
Default Issue resolved
Yes I had this same problem and I just bought my 2018 Silverado. The serviceguy said that it was completely normal... I said nooooo it’s not normal test it again... sure enough it was a problem with the exhaust damper. This he said caused the wrong compression and everything was getting out of whack. Note this is only 3 years old I’m afraid of other problems that will arise after my warranty is over.
country_09
13
Aug 26, 2021 6:54 PM
spidermonkey
Mar 28, 2015 6:24 AM
kpowell
May 8, 2013 1:21 PM
ntitan06
Oct 14, 2007 10:44 PM
jlenkows
Feb 13, 2007 11:44 AM
