Noise from behind gas cap
Old Mar 5, 2021 | 10:53 AM
Edgar Y Espino's Avatar
Default Noise from behind gas cap
ANYONE KNOW WHAT IS CAUSING THIS NOISE?
https://www.facebook.com/1488951896/videos/10220310845349797/
Old Mar 5, 2021 | 6:34 PM
Gumby22's Avatar
Probably the air compressor for the suspension. It’s mounted in that area. It could also be a broken line/fitting but usually they’re not that loud.
You’ll have to get underneath it to inspect for breaks. If none are found, the compressor needs replacement.
The compressor will engage with the key on engine off, but if you need to lift it, put Jack stands under the axle so the height sensors trigger the compressor.
IrishPsych
Oct 12, 2019 7:26 PM
Lance Bennett
Sep 20, 2019 10:35 AM
rickjbr
Jan 17, 2016 8:27 PM
TimC2520
Dec 29, 2015 2:26 PM
sjh5147
Mar 5, 2013 1:02 PM
