'08 Tahoe gas tank door spring broke off...
Old Mar 7, 2011 | 10:39 AM
hycaliber's Avatar
Default '08 Tahoe gas tank door spring broke off...
I was just filling up my tank ($89!) and the pump broke off the clip to the right of the tank opening that allows the gas tank door to pop open/closed.
Now the door is inverted. I called the Chevy dealership and they want an hour and $60.00 to fix it.
I have two questions
1) Can I open the door without scratching the paint? And how?
2) Since I haven't attempted to solve #1 and closed the door so I can't see how the clip attaches - Can I install the clip myself?
Sorry if this has been posted already, I tried searching but this clip (for $60 it should open my tank and fill itself) might have a name I can't find!
Old Mar 7, 2011 | 11:43 AM
Welcome to the forum.
I doubt that you can get the "clip" by itself. Best bet is a salvage yard and get the whole assembly.
Old Mar 8, 2011 | 3:16 PM
I misunderstood what you were referring to. I believe you are talking about the rubber covered, spring loaded gizmo that pops the door open. If so, pretty sure you should be able to buy that separately.
Old Mar 9, 2011 | 10:31 AM
The door hinge works on a fulcrum of sorts so you only need use something soft/rubber non metal to get under the door and lift it up and it should work as normal. The gizmo just gives the assist to get the door high enough so your finger can do the same...
Unfortunately the picture below does not feature the gizmo...
Attached Thumbnails '08 Tahoe gas tank door spring broke off...-fuel-door.jpg
Old Mar 9, 2011 | 10:45 AM
However... GM parts direct DOES have said gizmo listed
Attached Thumbnails '08 Tahoe gas tank door spring broke off...-fuel-door-spring-aka-gizmo.jpg
Old Mar 9, 2011 | 9:34 PM
HoleInOne's Avatar
The assembly just snaps in place. I replaced the one on my daughter's suburban. Around 20 bucks for part. 2 minutes for installation. I think the stealerships have a 1 hour minimum.
Old Aug 25, 2011 | 10:38 PM
mdc088's Avatar
Any idea what the part number is for the "gizmo?" I think it's item number 11 in in2pro's post.
Old Aug 28, 2011 | 8:26 PM
GM parts direct for a 2007
pn#20912532
Fuel Tank Filler Door
SPRING
$6.29
Old Aug 20, 2012 | 3:12 PM
barkermw's Avatar
New User
Awaiting E-mail Confirmation
I just bought the spring at the dealership $10, and once you remove the old spring assembly, you just slide the new one thru the slot and it clips into place...very simple. Removing the old one took the most time...had to break off the plastic clips on top and bottom, then it slid right out. literally only took minutes to do the entire job, that the dealership wanted $90 to do.
ahearnm
Mar 19, 2023 6:37 PM
TheFloridaBoy941
Oct 16, 2015 8:15 AM
chrisz71
Apr 24, 2013 10:55 PM
ilfyrfytr
Feb 2, 2010 4:38 PM
Guvner2
Site Feedback
Mar 28, 2009 7:56 PM
