09' 2500 Suburban Tires
Old Aug 23, 2013 | 2:37 PM
zboater's Avatar
Default 09' 2500 Suburban Tires
I am having a lot of vibration after changing my tires and looking for ideas. I have the factory 2500 wheels, and the original OEM tires were Bridgestone Duravis M700 265/70R17 (E). I was talked into replacing them with the Michelin LTX M/S2 265/70R17 (E). I have had a full alignment done and all is in spec. They have re-balanced the wheels 3 times now - 1 time on the road balance machine to balance under load. They are inflated to factory spec. They have verified that they are using the right weights for the wheel. I still have a ton of shaking in the seat (the passenger seat, seatbelt, etc. you can see vibrating extensively). I noticed the new tires are only 48lbs each (vs 54 lbs for the old ones), and the width of the new ones are 10.7" (vs 11.1" for the old ones). The car never shook for 65K miles before this and only started the day after I changed tires. What else could be causing this? Thanks in advance for the ideas. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Aug 23, 2013 | 3:31 PM
blueinterceptor's Avatar
When did you get the tires? Michelin had a do not sell order for tires made mid 2012 to mid 2013 or so. I had 1 tire fit the date code but they replaced all 4 because of the mileage difference.
I don't know if it affects the issue but it might be a start.
Old Aug 23, 2013 | 3:32 PM
Out of round tire(s), sidewall bubble, flat spot, belt shifted, but all unlikely since Michelin.
Have them road force balanced.
Old Aug 23, 2013 | 3:54 PM
zboater's Avatar
They were road force balanced by a differt tire company - no difference
Old Aug 23, 2013 | 3:55 PM
zboater's Avatar
3-4 weeks ago - have to look at the "do not sell" issue - public notice or dealer notice?
Old Aug 23, 2013 | 8:12 PM
it was a dealer notice. fyi about out of round Michelin
of the four original Michelin tires, one was out of round, the replaced tire was the one in the recall. so problems do come up..
Old Aug 23, 2013 | 8:23 PM
MDTAHOE's Avatar
Professional Mechanic
When does it vibrate? Above certain speeds? In a range of speeds? Only while stepping on accelerator? While braking?
It is possible weights came off. The person using the machine had no idea what they were doing. The machine had not been calibrated in a while.
What were the roadforce numbers? At my shop we match mount anything over 15 regardless if it is on a car truck or van. We give a print out of before and after numbers with every job (balance and road force). All of the roadforce machines have printers.
moespeeds
Mar 30, 2013 12:59 AM
Hcoisrupp
Oct 14, 2012 12:03 AM
JHarris8732
Nov 10, 2011 11:25 AM
dphd
Apr 21, 2011 1:17 AM
new_york_system
Mar 27, 2007 1:30 PM
