'15 Tahoe - Power in the Overhead Console
Old Apr 11, 2015 | 10:07 PM
Frank J's Avatar
Default '15 Tahoe - Power in the Overhead Console
Anybody opened the overhead console in their 2015 Tahoe? I powered my radar detector from the overhead console in my ’03 Suburban and would like to do the same in my new Tahoe. My primary question is how to open the console without breaking anything. If anyone has gone that far, is there any (ignition or ignition & accessory) power available inside? I could settle with constant power and having to turn off the detector when I shut down, but I would rather not. Any guidance would be appreciated.
Old Apr 12, 2015 | 8:02 AM
See if you can pop out the lamp lenses as that will give you a better view inside and likely access to retaining screws...
Old Apr 12, 2015 | 8:09 PM
While it is not switched power, it's a lot easier to take off the 12 volts from the back of the mirror. This also allows you to mount the detector up hi for better range and not as conspicuous.
Old Apr 13, 2015 | 7:15 AM
Here is a thread I did on a Dash cam in my 07, you should be able to find similar wiring for the mirror in the same location....
https://chevroletforum.com/forum/tah...m-63686/page2/
Old Apr 13, 2015 | 8:31 AM
SabrToothSqrl's Avatar
Default rear view
I've seen some ones that integrate the display into your rearview... which I think is pretty cool.
OKchevy4x4fan
Feb 9, 2010 11:06 AM
sadienrye
Mar 23, 2008 9:00 PM
goldenbetty55
May 16, 2007 9:03 PM
wildfireracing
May 10, 2007 10:53 PM
randk2005
Oct 31, 2006 6:47 PM
