17 Tahoe LT Power Rear Lift Gate Issue
Old Jul 8, 2020 | 9:38 AM
RedWax's Avatar
Default 17 Tahoe LT Power Rear Lift Gate Issue
Hi, all, new to the forum and glad to be here. Just purchased a used '17 Tahoe LT. Love it so far. Joined the forum as I love the Tahoe but am admittedly far less of a do-it-yourselfer and far less knowledgeable than the vast majority of members
I purchased the vehicle about a month ago, initially with no problems whatsoever. I've probably opened and closed the rear power liftgate hundreds of times already with no issues. Now, though, when I open the liftgate via either the key fob, interior button or gate itself, it will open just a few inches before shutting again. There doesn't seem to be any obstructions, and the gate will shut itself just fine once opened. I've also noticed that if I hold the gate and simply "guide" it slowly for the first few inches, it will open itself all the way after I let go.
Is anyone familiar with this issue or has anyone experienced it in the past? Is there a quick fix, or might I need a new part or sensor?
Thank you!
Old Jul 19, 2020 | 10:22 PM
burbanB's Avatar
Default Lithium Grease
Try spraying some lithium grease not wd40 on the hinges at the top once it is open and let it open and close a few times. The resistance from hinges being dry could cause the failsafe to kick in. If not you may need a diagnosis at dealer or such.
jholley
Aug 31, 2020 12:23 AM
sellinger87
Aug 3, 2020 11:47 PM
RedWax
Jul 8, 2020 9:31 AM
dmillerj
May 4, 2016 3:49 PM
56brew
Apr 15, 2008 8:20 AM
