1990 R1500 blower motor not running after heater core replacement
Old Nov 20, 2021 | 12:27 PM
relative4's Avatar
Default 1990 R1500 blower motor not running after heater core replacement
I just replaced the heater core in my friend's 1990 Suburban R1500, and now the blower doesn't run. I didn't knowingly disconnect any electrical connectors. Can anyone direct me to resources for a fuse diagram and wiring diagrams?
Also, does anyone know of any hot spots where I might have been likely to disconnect or pinch a wire during this job? If it makes a difference, it was the one where you have to remove the heater box with the 3 studs through the firewall, not the one where you pop the bottom off the heater box.
Thanks!
Old Nov 21, 2021 | 9:21 AM
Cusser's Avatar
I'd check the fuses first. Is the fuse diagram on the underside of the fuse cover?
Old Nov 26, 2021 | 10:46 AM
relative4's Avatar
For anyone researching the same problem, it was super simple. I accidentally disconnected the power wire to the blower while disconnecting the heater hoses.
Similar thread here:
https://www.gmtruckclub.com/threads/...r-wire.837386/
Old Nov 27, 2021 | 12:04 AM
oilcanhenry's Avatar
Way to go man!
Old Nov 27, 2021 | 9:02 AM
Cusser's Avatar
Thanks for posting the fix; many people fail to do the update.
And we've ALL done some stupid stuff in the past....
pinbill
Dec 23, 2014 11:34 AM
metaluzc
Jan 31, 2010 7:28 PM
jennkent5454
Jan 11, 2010 7:29 PM
Altarium
Jun 11, 2009 9:04 AM
dbiro
Feb 9, 2007 4:26 PM
