1993 Suburban leaking tranny fluid....
Old Aug 1, 2013 | 3:12 AM
Chevrolet1985's Avatar
Default 1993 Suburban leaking tranny fluid....
Hi guys,
I'm new to the site and would like to know some of your opinions. I'm not the best mechanic in the world and I'm not sure how to approach this. Obviously there is a problem because the transmission is leaking like crazy. What should I do? I don't want to take it to a garage and end up paying more than the truck is worth. Btw: the truck is a 2 wheel drive, 5.7 L V8, 1/2 ton suburban.
Old Aug 1, 2013 | 6:59 AM
Jeff Collision's Avatar
If the transmission has been leaking for a while fluid and dirt will have accumulated over the transmission. It will need to be cleaned to pinpoint the leak. Look closely around the service pan. Pan gaskets are the most common leak. These are easy to service and usually a new transmission filter is necessary. Replace the gasket and filter if the gasket is leaking. Look at the forward area of the transmission where it is bolted to the engine. If fluid is seeping from here, the front seal has failed, and the transmission must be removed for repair. This usually indicates the pump bushing has dislocated, allowing fluid to leak past the front seal. In this case, the transmission must be removed. If any connector is leaking the repair is internal. Access is gained through the pan and the transmission does not need to be removed. Remove the rad cap when the engine is cool. Inspect the fluid for oily, reddish-brown residue floating on top of the coolant. This indicates the transmission cooler is leaking and should be replaced. Consult a certified mechanic for major repair.
jherkel
15
Nov 27, 2014 10:44 AM
puterg33k
Jan 23, 2013 9:49 PM
DeHartShadow
Mar 28, 2010 10:10 PM
carson45
Jan 8, 2009 11:36 AM
Dhall15
Nov 6, 2006 8:00 PM
