1997 Suburban FUSE 8 crank mystery
Old Oct 9, 2019 | 11:35 PM
trund's Avatar
Default 1997 Suburban FUSE 8 crank mystery
My 1997 Suburban cranks and starts properly. If I pull FUSE 8 (labeled crank), the truck won't start. So far, so good. This is proper behavior.
However, when I test a FUSE 8 contact in the fuse box on the side of the dash with my 12v probe, the probe indicator does NOT light up. Why? The probe indicates 12v for all my other fuses. The probe works fine.
Old Oct 10, 2019 | 2:21 AM
oilcanhenry's Avatar
Might need to turn the ignition key ON. If it ain't broke..........................
Old Oct 10, 2019 | 1:37 PM
trund's Avatar
Default TRIED YOUR IDEA OILCANHENRY, but...
With the key in BOTH the accessories ON position AND also after the car starts, the FUSE 8 contact still does NOT light the 12v probe. Weird. I know you recommended that, "if it's not broken don't play around," but this is going to bother me. Any other ideas? Anyone?
Old Oct 11, 2019 | 5:31 AM
a55bruce's Avatar
The fuse probably only gets power while the key is in START position.
Old Oct 11, 2019 | 1:11 PM
trund's Avatar
Default Will test FUSE 8 with your start position idea
If so, a55Bruce, then the fuse will be live for a brief moment during starting, and the probe will light briefly. I'll test your idea and report the results in case others are interested. Thanks, oilcan and bruce.
Danielhurlbert
Mar 18, 2019 1:39 AM
Ronald Tobias Hughes
Oct 26, 2016 6:51 PM
Christopher Krumholt
May 17, 2013 6:10 AM
Tgoodrich3
Apr 25, 2012 8:36 PM
bigredburban
Aug 25, 2008 4:10 PM
