1997 suburban starting issues
Old Feb 20, 2022 | 1:55 PM
RM1974's Avatar
Default 1997 suburban starting issues
At times it will not crank . Turn the key and nothing . Check the fuses and all are good . Check for power on ignition fuse in dash side panel with key in on position with a test light and the truck cranks as soon as touched with test light ? Any one ran into this before ?
Old Feb 21, 2022 | 8:57 AM
repairman54's Avatar
Could be the switch or a crank relay. Try swapping relays first. There are other relays the same size in the fuse box.
trund
Oct 11, 2019 1:11 PM
Redz315
Uplander
Feb 5, 2018 6:30 AM
chazwel
Feb 14, 2012 7:38 AM
lalo93
Jan 15, 2012 1:51 PM
lromero
Aug 13, 2007 2:48 PM
