1998 BURB plug wires
Old Jan 13, 2023 | 7:27 PM
positron1998's Avatar
Default 1998 BURB plug wires
I bought a set of plug wires.
2 long wires equal size
2 wires slightly shorter equal size
The next pair of wires were the shortest of all BUT they are not equal. One is 2 inches shorter than the other
Question ////Does this sound right?
I have not started to change out the wires yet.
I am wondering if a shorter wire has been swapped to this set that I bought
The longer of the two short wires is ok and will reach the connections, but I am not sure about the shorter wire.
I hate to get all greasy and find the wire is not long enough to fit.
The short wires go at the back of the engine and the distance to each plug LOOKS the same but is hard to measuire.
Should I go ahead and remove a back wire and compare it to the shortest one in the set that I bought?
OR........is it a mistake in the set that the pair of short wires are not the same length?
Old Jan 14, 2023 | 5:36 AM
oilcanhenry's Avatar
Yeah I'd compare the short ones. They'll likely fit fine. No reason to do a job twice however.
Old Jan 14, 2023 | 6:06 AM
Thanks
Old Jan 16, 2023 | 10:12 AM
I'd remove the seven and eight wire and see which one of those is longer and use that as a guide.
Old Jan 17, 2023 | 5:58 AM
Thanks.............All the wires fit.
01S10AD
Dec 18, 2021 12:05 AM
jeff61
Jan 10, 2017 3:07 PM
old dog
Sep 6, 2009 4:30 PM
braggent
Jun 19, 2006 12:25 PM
