1999 Brakes
1999 Brakes
I have 147000 miles on her. The brakes suck. I just replaced rear shoes, and front pads. Why is the pedal still spongy, and go so far down when pressed? Thanks
RE: 1999 Brakes
Mines the same, it sucks. Alot of people is telling me to replace the brake lines with stainless steel, so I went ahead and bought a set from tirerack.com. I will be replacing it this weekend. I also got me the severe duty Hawk pads as well for the front. I will let you all know the results.
shawnvw <--- good comment on removing pins to lube it, I will make sure I do that.
RE: 1999 Brakes
On my 98 Burban the only thing that helped the spongy feeling was bleeding the rear brake line and replacing with new fluid. I can't explain it, just know that it worked!
JRich_taco
August 31st, 2013 12:16 AM
PKKK
March 1st, 2012 11:52 PM
Mille Racer 69
December 8th, 2010 8:26 PM
