1999 Brakes
Old Mar 8, 2008 | 8:15 AM
slingblade's Avatar
Default 1999 Brakes
I have 147000 miles on her. The brakes suck. I just replaced rear shoes, and front pads. Why is the pedal still spongy, and go so far down when pressed? Thanks
Old Mar 8, 2008 | 2:10 PM
shawnvw's Avatar
Banned
Default RE: 1999 Brakes
when you repplaced the rear shoes....did you set up the adjusters?
did you also remove the pins from the front calipers and lube them up?
Old Mar 19, 2008 | 11:39 AM
mf1026's Avatar
Mines the same, it sucks. Alot of people is telling me to replace the brake lines with stainless steel, so I went ahead and bought a set from tirerack.com. I will be replacing it this weekend. I also got me the severe duty Hawk pads as well for the front. I will let you all know the results.
shawnvw <--- good comment on removing pins to lube it, I will make sure I do that.
Old Mar 19, 2008 | 2:07 PM
misonido's Avatar
On my 98 Burban the only thing that helped the spongy feeling was bleeding the rear brake line and replacing with new fluid. I can't explain it, just know that it worked!
JRich_taco
Aug 31, 2013 12:16 AM
PKKK
Mar 1, 2012 11:52 PM
Mille Racer 69
Dec 8, 2010 8:26 PM
pwrcat
Nov 22, 2008 5:11 PM
hotrod032
Mar 20, 2008 9:34 PM
