1999 Suburban AC charge port
Old Jun 30, 2013 | 4:56 PM
Krashtrouble's Avatar
Default 1999 Suburban AC charge port
Can someone tell me which one of these ports are the ac charging port.
Old Jun 30, 2013 | 5:13 PM
It appears that you may have a dual AC , do you have a rear AC system?
If so both ports may be charging ports... the cold side is typically where the charge is added and I believe its the smaller of the two ports.... if you are using a auto store recharge can it should only fit on the correct port...
Old Jul 1, 2013 | 7:17 AM
Yes I have a rear ac system. So if the auto store recharge can fits on both portsthen they both need freon?
Old Jul 1, 2013 | 9:22 AM
Lets back up a little bit...
Why do you need to know which port is the recharge port, is the AC working but cooling?
Its possible to add too much Freon to the system and over charge it...
If the system is working but not getting cool enough it may need a charge, if its not working at all there may be more going on like a blown fuse, or bad pressure switch...
Old Jul 1, 2013 | 8:21 PM
In order to determine if it has enough freon, you need to put a set of gauges on it and check the pressures.
valewil5
Cruze
Feb 21, 2015 10:25 AM
dankorpi
Dec 4, 2013 11:43 PM
kayster
Nov 20, 2010 2:50 PM
gfraigun
Jan 22, 2007 3:12 PM
andregg1
Oct 1, 2006 2:51 PM
