1999 Suburban Grinding noise from front end
Old Feb 20, 2013 | 4:54 PM
ChevyBoy17's Avatar
Default 1999 Suburban Grinding noise from front end
I have a 1999 Chevrolet Suburban with 201000 miles and I noticed there's a grinding sound coming from the front end when it's on drive I can hear up to about 30 but then the motor is louder than the grinding so I can't hear it. Any ideas?
Old Feb 20, 2013 | 8:39 PM
cleveland63b's Avatar
brakes or wheel bearing maybe...more details?
Old Feb 27, 2013 | 10:21 PM
ChevyBoy17's Avatar
Well today I changed the brakes and rotors in the front. I had a guy look at it and he said that's what it was he wanted $400 to do it. I did it myself and only cost $80 in parts. They needed to be done it still sounds like its grinding. Any ideas what it could be? It does it only when driving and in 4wd as well. But it stops when I stop.
Old Feb 28, 2013 | 8:52 AM
hicksvilleshick's Avatar
front diff could be low on oil...
that many miles depending on how it was used the front diff could be wearing out.
Old Feb 28, 2013 | 8:25 PM
MDTAHOE's Avatar
Professional Mechanic
It would be almost impossible to diagnose a noise without hearing it. We could guess many parts but the fact is they are only a guess. Each persons description of a noise maybe different. A grind to you maybe a squeak or a rubbing noise to someone else. A forum is the wrong place to get help with a noise. Just because person "A" had a noise that was the front diff does not mean every "grinding noise " everyone else had is the same thing. If you paid the guy to tell you it was the brakes then take it back to him. If he did it for free then you got exactly what you paid for. Sorry but I am just keeping it real. If you can not find it yourself then you need to pay someone qualified to find it for you.
Old Feb 28, 2013 | 9:12 PM
I would have to agree with MDTAHOE's everyone's version of grinding vs rubbing...
You could try getting it up off the ground and spin each wheel..
might even try putting it in gear while securely and properly supported off the ground in both 2 and 4 wheel mode....
Schill
Feb 23, 2013 2:14 PM
PG2676
Uplander
Sep 22, 2012 1:54 PM
Chris9793
Mar 15, 2012 9:37 PM
parker12
Aug 26, 2011 3:16 PM
mcculleb
Dec 8, 2007 2:01 PM
