1999 Tahoe Rear A/C Blower
Old January 10th, 2023, 8:58 AM
rosyod96's Avatar
Default 1999 Tahoe Rear A/C Blower
Good day,
I am having issues with the 10amp fuse (RR BLWR) blowing in my 1999 tahoe that controls the blower for rear a/c. I have searched the forums and web without finding anything too useful. Anyone have an idea where to start or what the cause may be?
The front ac works great and the 50amp in the engine bay does not blow.
thanks
Old January 10th, 2023, 9:19 AM
Cusser's Avatar
If mine, I'd disconnect the wire harness to the rear blower motor itself, likely is 2-wire connector. Then turn on the system; if a new fuse doesn't blow, replace the rear blower motor. So try that, report back.
Rednucleus (January 10th, 2023)
Old January 10th, 2023, 9:32 AM
Unplug the power plug at the blower motor, if it still blows the fuse then your problem is in the wiring. If it does not blow the fuse the problem is in the blower motor or resistor.
Old January 10th, 2023, 9:41 AM
rosyod96's Avatar
Ok thanks for the advice…I’m fairly new to these so is the blower motor for the rear located on the right hand side of the cargo area?
Old January 10th, 2023, 9:43 AM
rosyod96's Avatar
Also I might add that when I replace the fuse it doesn’t always blow right away. The blower will work for a few minutes before popping the fuse…
Old January 10th, 2023, 9:56 AM
Cusser's Avatar
Old January 10th, 2023, 9:59 AM
rosyod96's Avatar
Thanks for those links! I had seen them but wasn’t sure if it was same in the older style tahoes….
Old January 10th, 2023, 10:09 AM
Rednucleus's Avatar
I'll bet your fix is a new motor. Please report back on the fix!
Old January 10th, 2023, 1:59 PM
rosyod96's Avatar
Welp, unplugged the blower and fuse is holding strong. Looks like a new blower for me! Any recommendations? Must go OEM? or any highly rated aftermarket blowers? Junkyard?
Old January 10th, 2023, 2:01 PM
rosyod96's Avatar
The current one looks like a unimotor 35015 …? Made in Canada. Is that OEM or already an aftermarket?
Quick Reply: 1999 Tahoe Rear A/C Blower
