2000 suburban low speed thumping noise
Old May 26, 2013 | 7:37 PM
2000suburbanjeff's Avatar
Default 2000 suburban low speed thumping noise
I have 2000 suburban 1500 keep hearing a thumping noise at 5 to 15 mph while backing up or driving after it goes away at fast speeds.need help here.
Old May 26, 2013 | 8:34 PM
xitjustice's Avatar
being that it happens at low speeds, would be pretty easy to have someone drive it as you watch it go bye. A tool called 'chassis ears' would be ideal in this situation.
Not affected by engine speed?
Under load?
Only reverse?
Old May 26, 2013 | 8:45 PM
it only happends at 5 to 15 mph constantly.in reverse and drive it make the noise.
Old May 27, 2013 | 10:09 AM
Have you inspected the underside of the vehicle for:
Anything wrapped around the drive shaft
Checked the U joints front and back
Jacked the vehicle up off the ground and rotated each wheel in both directions checking for a wobble or anything stuck in the tire
Inspect the transmission and motor mounts for cracks or tears...
Think like a thump.. those are the things and places I would check...
Old May 30, 2013 | 11:40 PM
Smithfamilyof7's Avatar
My 02 Suburban sometimes makes a weird thumping noise. It's almost always when I'm just backing out of the driveway, but once or twice has done it when I'm less than a block away. Doesn't always do it. Only does it once, when it does it. But it sounds like something is dropping near my glovebox. In fact, I always look over there because I think it's actually something dropping. lol. Does this sound like what yours does?
shade23
Mar 14, 2014 8:51 AM
Toddbrandon28
Feb 27, 2014 8:02 AM
musclecarenvy
Mar 26, 2010 1:47 PM
radio_earbug
Sonic (Aveo)
Jul 27, 2009 2:14 PM
