2000 Tahoe won't start when warmed up.
Old Dec 8, 2020 | 1:38 PM
Nya Quintana-Tutt's Avatar
Default 2000 Tahoe won't start when warmed up.
Please help.....Ok so my 2000 Tahoe with a 5.3 in it starts and drives perfectly. It isn't giving me any codes either. But if I turn it off after it is warmed up it won't start until it cools down (about 45 minutes later) . does anyone have any idea what it could be?. Also I recently replaced the fuel pump and fuel filter. Also all o2 sensors, I ran fuel cleaner through it, and I replaced the coolant temperature sensor.
Old Dec 9, 2020 | 7:53 AM
repairman54's Avatar
When you say start do you mean it's not cranking over or not firing up ? That info description is very important.
If not firing up try flooring the gas pedal and see if that makes a difference on how it fires up.
Old Dec 9, 2020 | 8:45 AM
+1. could be fuel pressure leak down either thru the injectors or fpr. clear flood mode start will help determine if that is the direction to follow.
artimious7
Dec 15, 2020 5:10 PM
bigklu18
Apr 9, 2016 4:43 PM
bull463
Nov 11, 2011 6:52 AM
silverado man
May 5, 2008 11:53 AM
ib042129
Oct 3, 2007 11:11 AM
