2001 1500 Burb
Old Jul 5, 2012 | 3:23 PM
daytooday's Avatar
Default 2001 1500 Burb
Last year I started noticing a slight ticking sound when I would put a load on the burb. Like passing oor pulling a big hill etc. The other day out of the blue it got much worse. Most of the time below 50mph youdon't notice it but above that it is getting very loud. It sounds like it is coming from just below the fuel injectors. I forgot the way the cylinders are numbered but it is coming from the drivers side either the 1st or 2nd cylinder from the front of the vehicle. It is the 2wd v8. How hard is it to tear it down to the valve springs.
Old Jul 5, 2012 | 3:42 PM
daytooday's Avatar
Also, is there any way to diagnose the problem without tearing it down. I have Sea foamed it with a full can and it didn't help
Old Jul 5, 2012 | 8:48 PM
It could be valve lash, something else to consider is a connecting rod cap but that would be heard more at the bottom of the engine...
Old Jul 5, 2012 | 8:51 PM
Oh and the drivers side is 1,3,5,7 front to back
Old Jul 7, 2012 | 6:04 PM
daytooday's Avatar
Default thanks???
Thanks for your help but what is valve lash i have never heard bthat before and hiw can i tell if that is it. Thanks again and for any more help u might give
Old Jul 7, 2012 | 9:41 PM
On hydraulic lifters, you adjust 'til the clatter stops and then 1 1/2 turns beyond that to center the lifter plunger in the lifter body.
Old Jul 8, 2012 | 9:41 PM
spyncycle's Avatar
Do the adjusting while the engine is idling.
Old Jul 8, 2012 | 11:03 PM
And you can get clips that cover the squirter holes in the rocker arms and it cuts down on the mess.
Old Jul 11, 2012 | 1:24 PM
daytooday's Avatar
I have posted on here several times over the years and always get either a smart assed answer or none at all. So thank you so much for your help it is greatly appreciated
Old Jul 12, 2012 | 8:38 PM
Not sure what you are referring to. I counted five answers, none of which were other than legitimate suggestions.
Or did you mean this was the first time you actually got help?
Hopefully the latter.
