2001 Suburban Power outlets
Old May 22, 2015 | 4:32 PM
Deviat's Avatar
Default 2001 Suburban Power outlets
Need a little help here...
bought this suburban a week ago, and getting started to fix the "little" things I found wrong, like no power to the outlets, and no Horn. Replaced fuse since it was blown but still no power, pulled the face to check power to wires, only to NOT HAVE ANY WIRING HARNESS VISIBLE!!! Can anyone point me where these wires start around? Don't want to pull apart the dash farther than necessary to find them. Is there a secondary harness that could be missing? I see a small 4-pin connector behind and under the HVAC controls... Photos below.
Attached Thumbnails 2001 Suburban Power outlets-power1.jpg   2001 Suburban Power outlets-power2.jpg
Old May 26, 2015 | 3:38 PM
Deviat's Avatar
Following up to this, is this even a stock 2001 center console? Every console I find that is in a 2001 looks like it has an extension, not the same design.
I did find some wiring that looks like it is stuck under that plastic portion, I will pull the center console to confirm if these are the correct connectors, but looks like I may need to find a different avenue for the rear power port and the radio in the back panel.
Any opinions?
Old May 26, 2015 | 7:05 PM
surveyor134's Avatar
looks like my 06 2500 lt3 but never had it apart, I have seen a 6 cd player in one of the cutouts, the larger one
MaxT
Mar 4, 2014 8:48 AM
jlutty3
Avalanche
Nov 1, 2010 9:45 AM
Maui Blue
Sonic (Aveo)
Aug 4, 2009 2:20 PM
tankie2
Sonic (Aveo)
Apr 12, 2008 5:30 PM
