2001 Suburban quitting
Old Jul 26, 2011 | 11:48 AM
daytooday's Avatar
Default 2001 Suburban quitting
Several days ago my suburban would start and die as soon as i let off the gas. I moved it to the back where I could work on it. A few hours later I went out and cranked it and it worked fine. Now after driving it several times over a few days, I went to crank it today and the same thing as soon as I let off the gas it quits. It sounds as if it is choking then it quits.
Help
Old Jul 26, 2011 | 2:05 PM
hicksvilleshick's Avatar
Help
I would check the fuel filter. if thats good then I'd put a guage on it and make sure your getting the required pressure (fuel pressure)
:chug:
Old Jul 26, 2011 | 5:45 PM
daytooday's Avatar
In January I put in a new fuel filter fuel pump and fuel regulator or what ever it is. Again after a few minutes of sitting it cranked and is running ok.
Old Jul 26, 2011 | 7:26 PM
might still be worth checking incase you got a defective part...
I replaced the ignition module on my 90 pickup and swore up and down a few months later that wasn't the problem I was having at the time... after needlessly replacing a coil and chasing wiring down, I had the module tested and replaced under warranty...
I just wouldn't rule any of what you've replaced out... how much fuel did it have when it was doing this?
:chug:
dgwestfall
Apr 9, 2008 2:53 PM
EuropeanAuto
Dec 13, 2006 2:25 PM
birdie6463
Oct 16, 2006 3:17 PM
BillV
Feb 19, 2006 4:20 PM
