2001 Suburban-Strange Electrical Problem
Hello!
I recently started driving a 2001 Suburban with 104k on the clock. About a week ago, I was backing out of the driveway, and shifted from reverse to drive and a fairly loud "click" (electrical sounding) came from under the hood, the voltmeter drops severely and all the electronics shut off (for a split second). The same thing happened that afternoon as I was leaving school (after having sat for 7-8 hours), so I thought it only happened when it was cold. Today I was driving around, parked and went in a store, came back out and it did it when it was warm. Quicklist:
1.) Electrical clicking sound coming from under the hood. (Kind of like a short blast from a mig welder)
2.) Only occurs when shifting into drive. I can shift into reverse normally, but when I go to put it in drive, I get the sound and symptoms.
3.) Does not happen every time I change gears. It appears to be random with a frequency when it's cold.
4.) I know I have a weak battery. I've been meaning to replace it, but I haven't gone to get another one.
Any help will be greatly appreciated!
CountryMusicCTD Welcome to the forum ![Smile](https://chevroletforum.com/forum/images/smilies/smile.gif)
The battery could very well be the issue, you might want to check the battery connections to ensure they are clean and tight....
Remove the terminals and clean with a stiff brush, also check the ground cable from the battery to the block and body for a good fit and no corrosion...
And after you do that, get a free battery and alternator check at a local auto parts store like Advance Auto. I agree w/ in2pro that it sure sounds like a bad connection.
dalkins1
September 2nd, 2010 12:11 AM
ndh87
March 10th, 2009 6:14 AM
