2001 Suburban-Strange Electrical Problem
Hello!
I recently started driving a 2001 Suburban with 104k on the clock. About a week ago, I was backing out of the driveway, and shifted from reverse to drive and a fairly loud "click" (electrical sounding) came from under the hood, the voltmeter drops severely and all the electronics shut off (for a split second). The same thing happened that afternoon as I was leaving school (after having sat for 7-8 hours), so I thought it only happened when it was cold. Today I was driving around, parked and went in a store, came back out and it did it when it was warm. Quicklist:
1.) Electrical clicking sound coming from under the hood. (Kind of like a short blast from a mig welder)
2.) Only occurs when shifting into drive. I can shift into reverse normally, but when I go to put it in drive, I get the sound and symptoms.
3.) Does not happen every time I change gears. It appears to be random with a frequency when it's cold.
4.) I know I have a weak battery. I've been meaning to replace it, but I haven't gone to get another one.
Any help will be greatly appreciated!
CountryMusicCTD Welcome to the forum
The battery could very well be the issue, you might want to check the battery connections to ensure they are clean and tight....
Remove the terminals and clean with a stiff brush, also check the ground cable from the battery to the block and body for a good fit and no corrosion...
ndh87
Mar 10, 2009 6:14 AM
