2001 Tahoe fuel prob/annoyance
Old Sep 18, 2009 | 8:53 AM
TqMnster's Avatar
Default 2001 Tahoe fuel prob/annoyance
Well its not so much a problem yet but just aggravation sitting there having to crank it 2-3 times to get it to start. It isnt all the time but I'd say a good 50% and I have yet to see a common cause. I know the problem is fuel pressure bleedoff because I went to install a new filter the other day. Drove it into the shop and not even two minutes later there 0 psi on the line. I rented a pressure tester yesterday and found out when I first turn the key to ON (this is on a warm motor) it jumps up to 55 psi and falls off immediately and is at 0psi within a few seconds. When running the pressure sits at 50psi at idle. Does this sound normal? Once I cut it off the pressure immediately falls back off to 0 within maybe 10-15 seconds. Leaking down that fast leads me to believe the pump is letting it bleed back through. Is there a way to test this or any input you could give me before I start throwing parts at it. Although I've narrowed it down to the regulator ($50) or pump assembly ($280) Thanks!
Old Sep 21, 2009 | 5:31 PM
Welcome to the forum.
Have you tried starting after the key has been on for a few seconds to allow pressure to build up?
Old Sep 21, 2009 | 5:40 PM
myotherchevyisablazer's Avatar
change the pump and go from there....
Old Sep 21, 2009 | 7:11 PM
TqMnster's Avatar
Well after pinching off the return line and still losing pressure I decided it HAD to be the fuel pump so I went ahead and dropped the tank sunday at noon and had it back in and running like a champ by 3 in the midst of getting sidetracked with my gf and dog lol Usually things arent that easy but this time I was very reluctant after a little research and some common sense/diagnosis.
ChuckinTX
Mar 24, 2013 3:27 AM
knakki
Oct 22, 2010 7:10 PM
colin mctaggart
Aug 28, 2010 4:54 PM
brolajit
Apr 25, 2010 12:08 AM
jcbdelta1
Astro
Mar 14, 2010 11:23 AM
