2002 suburban 1500 which brake rotors and calipers
Old Oct 5, 2021 | 6:36 PM
hightekkrednek's Avatar
Default 2002 suburban 1500 which brake rotors and calipers
Hi guys. I have a 2002 suburban 1500 4x4 with a build date of 01/02. Attaching picture of build code sticker below. I’m not sure which rear rotors to go with, the 325 or 330mm. I have read where there is also an offset between rotors that will destroy your brakes fast if you don’t get the right ones and I’m not sure the last rotors put on by the last owners were the right ones to compare new ones to. Anyone have any input or know what else I can check to make sure I get the right rotors and calipers? Thank you
Old Oct 5, 2021 | 9:17 PM
oilcanhenry's Avatar
I'd go with Akebono Full Ceramic brake pads. Those will stop your vehicle quickly.
Old Oct 6, 2021 | 7:27 AM
repairman54's Avatar
You have a G80 limited slip rear end. Most listings for rear rotors mention with or without limited slip which may indicate size. Pull a tire off and measure the rotors size.
tnchevyman
Jun 14, 2017 11:19 AM
Chevy_07
Dec 1, 2014 6:27 AM
Rickoo
Mar 19, 2013 7:36 AM
pervitizm
Oct 1, 2012 1:32 AM
Danistheman1234
Apr 20, 2011 4:38 PM
