2002 Suburban Batt, Low Fuel, Security Msg Center etc.
Hi all!
Have what seems to be a common GM problem with no clear answer.
The message center is cycling "Security" "Low Fuel" battery emblem. The air bag and OnStar lights are illuminated. The fuel and temp gauge register zero. The high beam indicator does not illuminate. The gear selector does not show which gear is selected but the odometer and trip both register mileage. The security light will not go out when the vehicle is off, key removed and locked, drains battery. The vehicle runs fine, alternator charges at 14.2, grounds and battery connections are clean and tight. All other vehicle functions work. Have tried disconnecting battery to reset computer.
Really weird how many forums have this same problem but with no good answer.
Please help!!!!
Thanks!
Please help!!!!
Thanks!
hi all!
Have what seems to be a common gm problem with no clear answer.
The message center is cycling "security" "low fuel" battery emblem. The air bag and onstar lights are illuminated. The fuel and temp gauge register zero. The high beam indicator does not illuminate. The gear selector does not show which gear is selected but the odometer and trip both register mileage. The security light will not go out when the vehicle is off, key removed and locked, drains battery. The vehicle runs fine, alternator charges at 14.2, grounds and battery connections are clean and tight. All other vehicle functions work. Have tried disconnecting battery to reset computer.
Please help!!!!
Thanks!
Please help!!!!
Thanks!
@s10261931robert
ranchonion hasn't been here in a couple of years and is unlikely to reply to you. You're better off posting your own thread, and providing the necessary information to help you. (ie your vehicle details, trouble codes, troubleshooting you tried, etc.). Thanks.
Lance Wheeler
Nov 11, 2012 8:15 PM
anthem777
Jul 31, 2007 5:56 AM
